Stuck front hub on a TU155
   / Stuck front hub on a TU155 #1
Chris_in_Oz
South of Perth, Western Australia
Iseki TU155 Landhope
This was logged as stiff steering, but it has turned out to be a seized hub..
I thought it best to disconnect a few things and try the steering, just to confirm that the steering box was the culprit. I dropped off the track rods from the steering arm to the front hubs and the steering was as light as a feather!
(BTW - does anyone know if there is a generic "boot" or "gaiter" for the track-rod ends - the rubber gaitors on all of mine are trashed, but the joints are good).
Re-connected, dropped the tractor off the ramps, jacked it up in the middle, took them back off and it turns out to be the right-hand hub is reluctant to turn. Left side is great and the right is so tight that I need to put a bar on the arm to be able to move it.
SO - what do I do about a stiff hub? It rotates fine, just won't turn.
How do these come apart? Any idea where I start?
2012 RAM 5500 (A52472)
2013 Ford Escape Multipurpose Vehicle (MPV), VIN # 1FMCU0F77DUB50591 (A51572)
2013 Ford Escape...
2018 CATERPILLAR 259D SKID STEER (A51246)
2018 CATERPILLAR...
2017 TRANSCRAFT TANDEM AXLE DROP DECK TRAILER (A52576)
2017 TRANSCRAFT...
2019 GEHL R105 WHEELED SKID STEER (A51242)
2019 GEHL R105...
New/Unused Fuel Pump with 50ft of Hose (A51573)
New/Unused Fuel...
