stuck clutch solved
   / stuck clutch solved #1
BARNACLE BILL
FORD 3000
FYI ---- I HAD STUCK CLUTCH (HIGH SUMMER HUMIDITY RUSTED CLUTCH PLATE TO FLYWHEEL) ON MY FORD 3000. YAS ALL GAVE ME SOME GOOD ADVICE AND I FINALLY SOLVED THE PROBLEM. I HOOKED TO A 2 BOTTOM PLOW / FOUND THE HARDEST GROUND POSSIBLE AND PLOWED FOR AN HOUR PUSHING THE CLUTCH PEDAL FREQUENTLY WITH NO RESULTS. I THEN TIED THE CLUTCH PEDAL DOWN AND AFTER ANOTHER 1/2 HOUR PLOWING IT FINALLY BROKE LOOSE. ALL IS WELL. THANKS FOR YOUR INPUT.
BAR BILL
   / stuck clutch solved #2
I have had that happen a couple times with my 5000. I idled the bucket up against a tree and shut it off. Then I started it in a higher gear and it broke loose. I am sure people will find fault with that method but it worked for me.
   / stuck clutch solved #3
I'm sorry, I started it in neutral and then bumped it into a higherr gear as carefully as I could.
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
TEST BID LOT (A50775)
2011 4300M7 International (Pavo, GA) (A50123)
2011 4300M7...
20711 (A50323)
20711 (A50323)
2016 CATERPILLAR 259D SKID STEER (A52705)
2016 CATERPILLAR...
