stuck 1864
   / stuck 1864 #1
ken williams
i have a cub cadet 1864 which has frozen the linkage will not move hence the tractor is stuck it will move slowly bun not fast enough to be useful
   / stuck 1864 #2
Hi Ken, if I understand you correctly the tractor starts and runs fine but the hydro lever won't move. Take a look at your brake linkage, see if when you lift the brake pedal the linkage is moving OK and releasing the brakes and the hydro lever. Since when you push down the brake the hydro returns to "neutral", that same linkage has to allow the lever to move when the brake is up. Hope this makes sense.
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A53473)
2012 UNVERFERTH...
2015 Kia Sedona Van (A51694)
2015 Kia Sedona...
2013 FREIGHTLINER EXT CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
TRASH TRAILER 16 T/A (A52472)
TRASH TRAILER 16...
FAKE (A52472)
FAKE (A52472)
