Stubborn Quick Connect after winter??
   / Stubborn Quick Connect after winter?? #1
4000su
Can't get my grapple aux hose quick connection to engage. It's a straight connection so no way to bang on it to fully engage. The tractor side ball is free but I'm thinking maybe the grapple cylinder hose end ball is frozen or too much pressure on that end? Tried hitting the male ball with wooden handle to see if it might be frozen. Still no luck. It was really hard to get the other hose to connect as well but I was able finally do it using a wrench up against fitting and hit with a hammer. Can't quite do the same method on this side. Any other ideas to free it up?
   / Stubborn Quick Connect after winter?? #2
Loosen the hose fitting connecting that coupler and tighten again. This should relieve any pressure in the system.
   / Stubborn Quick Connect after winter?? #3
You need to remove some fluid ever how you do it.
Most people just press the male QD against a hard surface or use a brass rod or wooden dowel and use a rag over the fitting and tap with a hammer.
As a last resort, loosen the QD on the attachment side and release some fluid.
You could make up a dummy QD with a short piece of PVC and a rag stuffed inside the PVC to plug into the attachment QD when you remove it from the tractor, and your trouble will go away.
thanks, I loosened the cylinder end to drain some fluid and then whacked the ball and that did the trick. Went easily together. Will do this every spring before hooking up the grapple to save time and a bunch of cussing!.
2018 Ford Explorer AWD SUV (A55758)
2018 Ford Explorer...
2019 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A54607)
2019 FREIGHTLINER...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2019 JOHN DEERE Z960M ZERO TURN LAWN MOWER (A54756)
2019 JOHN DEERE...
2009 JOHN DEERE 544K WHEEL LOADER (A52705)
2009 JOHN DEERE...
