newbury
Super Star Member
- Joined
- Jan 8, 2009
- Messages
- 13,974
- Location
- From Vt, in Va, retiring to MS
- Tractor
- Kubota's - B7610, M4700
I've got a lot of vinyl wallpaper/shelf paper border to strip. The thick stuff with strong adhesive. I tried scraping it off. I tried using a heat gun and scraping it off. VERY slow progress.
If you've ever had to take off shelf paper you'd know my problem. Often you end up pulling the top layer of drywall off requiring lots of skim coating or tearing the drywall out and replacing it. I have done two rooms at another house where the prior owner did all the walls in shelf paper and I ended up replacing a LOT of drywall. I tried detergent and other solutions to soften the glue but I always ended up ripping off drywall paper.
I bought some Citri strip and soaked it for a couple of hours. Slightly better but still slow, plus I'm working on a ladder with arms extended. I used the heat gun to remove the top vinyl layer and soaked the remaining paper with Citristrip and left it over night. Then used the heat gun and scraper. It's now coming off slowly, like pushing the scraper thru thick semihardened glue. BUT NO TEARING OF THE DRYWALL!!
I think I've got the process down now. Heat with gun, strip top vinyl layer, soak paper for at LEAST 8 hours, scrape using heat gun.
I hate vinyl wallpaper and shelf paper.
