STRIPPING TOP SOIL
   / STRIPPING TOP SOIL #1
jjcc246
Buffalo, New York
2004 TC30
I'm stripping top soil for a 28' x 32' garage i'm building. I'm using my TC-30 with a FEL. What i'm doing right now is curling the bucket all the way back and cutting and dragging the soil. I'm getting a lot of "skip" on the bucket making the ground uneven and going over it several times to try and smooth it out, thus taking a very long time. Anybody out there have a better way of doing it without hiring someone with a dozer? I'm doing a floating concrete slab and I want to get it on solid ground to lessen the chance of heving and craking. Thanks in advance for your replies.
   / STRIPPING TOP SOIL #3
I ran into the same problem stripping topsoil from another part of my property to help the grass around the house. The solution that worked for me was to do the stripping with my box scraper first and shove it into a pile, then use the bucket to scoop it out of the pile for transport. I had a lot easier time keeping the grade consistent and not digging into clay once I stopped trying to do it all with the loader. Worked for me; give it a shot and see how it works for you.
   / STRIPPING TOP SOIL #4
What I've been doing is to tilt the bucket forward slightly so the lip digs a couple inches, and then I drive forward real slow, and control the bucket depth and pitch depending on how the tractor is moving. To smooth/level out after I've dug, I did what you are doing, tilt the bucket forward so the bottom is just less than vertical, and then drag backwards with the lip just slightly above the ground. This was just to push around loose piles and ridges. Then I packed it down by back dragging with the bucket tilted just forward of level and driving backwards. I put down pressure on the bucket while doing this. This worked pretty well for me to level off an area I'm working on, but I wasn't removing all the top soil, just spreading it around to flatten out the area.
   / STRIPPING TOP SOIL #5
It's tough stripping topsoil with our relatively smaller machines. But going forward is alot faster than going backward. If it were me I'd try a boxblade (I don't have one but heard it works better than the FEL for this application) or better yet get someone with a dozer and it'll be done in 30 minutes.
Rich
   / STRIPPING TOP SOIL #6
I think the boxblade is the best tool to use for your job.
   / STRIPPING TOP SOIL #7
Rototill the topsoil first.
I recently put in my 600' driveway and park area this way and it was by far the easiest way I've tryed .
Tilled the topsoil to full depth, made removal very easy, no ripping and tearing trying to cut the topsoil loose, the tilled soil was very easy to work with when used in other areas after removal.
The untilled soil underneath is smooth from the tiller, very little extra leveling was needed.
   / STRIPPING TOP SOIL #8
Your best bet is to hire this out. The hills and valleys you are creating will make a poor base for the concrete slab. More than likely the valleys will contain loose dirt that is not compacted. If you are going to do it, make sure you rake out all the loose dirt, (you'll probably need more concrete...)
Are you pouring the slab on top of the subsoil, or are you going to bring in some stone a compact that for a base before you pour? I've seen it done both ways, the garages with slabs on compacted stone seem to have fewer cracks.
   / STRIPPING TOP SOIL #9
I actually got the topsoil up using my back blade. I extended the top link and the blade cut right under the sod and kept curling it. Give it a try. It worked for me. That was without extra weight on it also.
   / STRIPPING TOP SOIL #10
I remove the top soil by going foward, not trying to do it all at once, but a little a time. I remove a little going one way and if it starts looking bad I turn around and come at it from a different direction. My best work happens when I work slow. Kevin
2015 Ford Fusion Sedan (A42744)
2015 Ford Fusion...
More info coming soon! (A44572)
More info coming...
2017 Ford Explorer AWD SUV (A42744)
2017 Ford Explorer...
Pallet of Irrigation Hose (A44502)
Pallet of...
2006 ADVANCE ENGINEERED PRODUCTS PNEUMATIC TRAILER (A45333)
2006 ADVANCE...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A44572)
Year: 2016 Make...
