Stress crack in wheel motor
   / Stress crack in wheel motor #1
smilindave
Bronze Member
Dayton, Pa
Power Trac 425
Front wheel motor on my 425 started leaking a while back. The other day it finally blew. Oil everywhere. I took the motor off and had new seals put in. Still leaked. After closer inspection, i found a hairline crack on the face of the motor near the main seal. Is there any chance I can have it welded, re-machined and a new seal kit installed?
   / Stress crack in wheel motor #2
What kind of wheel motors do you have? If your machine is mid 2003 or newer, then they are Whites. You can get a new motor for a little over $300, if you shop carefully.
Welding up a stress crack to withstand 2500 PSI seems like a tricky proposition. Maybe a good weldor could do it, if the area in question did not have a precision machined finish. You also may be able to buy a new case for the motor.
Can you provide a photo of the leaking area?
The motor is a White form a 2000 model. I'm worried about getting a good tight weld that will seal the crack, especially in the area around the seal. as for the picture, I don't have access to a digital camera.
   / Stress crack in wheel motor #4
Just curious if you were using reversed wheels?
I did have the back wheels reversed for a while to move some dirt, but when I was done I switched them back. However it is one of the front motors that went bad.
   / Stress crack in wheel motor #6
Without knowing where the crack is, it is hard to comment in detail. In general, welding a hairline crack is not recommended on a machined part, as you need to penetrate deep enough into the metal to fuse the body.
If it just on the lip that holds the o-ring, maybe. However, I think that the welding/machining bill would outweigh the price of a new motor.
All the best,
Peter
thanks, i will probably just end up getting a new one just to be on the safe side.
1998 Talbert TDW-35S-HRG-1-T1 Detach, GVWR 84,300 (A52384)
1998 Talbert...
2020 Kubota MX5400 (A50123)
2020 Kubota MX5400...
2023 UNVERFERTH 432 (A53084)
2023 UNVERFERTH...
2008 Ford F-450 SD 4WD Pickup Truck (A53117)
2008 Ford F-450 SD...
2014 Chevrolet Tahoe SUV (A51694)
2014 Chevrolet...
HEAVY DUTY TRACTOR BRUSH GUARD (A51247)
HEAVY DUTY TRACTOR...
