ERE
This is a problem I had some time back and thought I solved by replacing the 5 year old battery. Unfortunately, replacement didn't correct the problem and I'm short on ideas as to where to look. The problem is that when I turn the key, I get normal glow plug timing but when I turn the key the rest of the way to start it it clunks like the solenoid is trying to engage the motor to the flywheel, but the engine doesn't crank. If I release the key and immediately twist it full over, the engine cranks and starts. The crank sounds sort of wimpy to me, however. Voltages are good on the battery and the alternator when it is running. Battery terminals are clean and tight, the ground connection is clean and tight.
Has anyone seen this type of problem, or have any ideas for trouble shooting. So far I'm still in business, but I'm pretty worried with winter weather around the corner.
