Strange intermittent diesel starting problem
/ Strange intermittent diesel starting problem #1
kolkmeyer
Mahindra 2015
Six months ago I purchased a used 2006 20 hp Mahindra diesel with 400 hours. There is a three second glow plug light, and until recently it always started as soon as the glow plug light went out and you hit the ignition switch. Right before the problem started, I thought I noticed an unusual puff of black smoke on several occasions when I started the tractor. Soon after, it turned over just fine, but the engine would not fire at all. There is a fair amount of black smoke as the starter spins the engine, which I believe indicates an adequate fuel supply. After trying to start the tractor every day for a week, I skipped several days. After two days It started with no hesitation. I was able to stop and start it all that day, but the next day it would once again turn over but not start. No luck for another week until skipping a few days, then it immediately started again. This week it did not start after skipping several days. When it won't start it sometimes makes a buzzing-howling noise as it is turning over. I have tried starting it without the air filter with no luck. After reading warnings about using starter fluid in diesels, I did try several squirts of WD-40 in the breather hose. That didn't help either, but it may not have reached the engine. I'm in the middle of no-where and would greatly appreciate any suggestions. I have limited computer access so please excuse my slow response to questions. If it would be easier to talk on the phone, feel free to call John at 417-429-3037. Thanks
/ Strange intermittent diesel starting problem #2
G'day check all battery connections are clean and tight if that does not help have you tried to jump start? It sounds a bit like it is not spinning over quick enough.
Jon
/ Strange intermittent diesel starting problem #3
I had a similar problem turned out to be a bit of corrosion on the bar that connects the glow plugs to each other. I took it off cleaned the connections with fine sandpaper and was good to go. took about 5 minutes.
/ Strange intermittent diesel starting problem #4
You may have fried the glow plug controller or even a glow plug. Do the simple things first. Verify that they are getting power, that they are getting warm, etc.
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
2023 Kubota Z252KH-54 Zero Turn Mower (A63689)
2023 Kubota...
2008 MACK CHU613 DUMP TRUCK (A63569)
2008 MACK CHU613...
Tube Line Manure Spreader Nitro 750 (A63688)
Tube Line Manure...
2007 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A62130)
2007 CHEVROLET...
2018 John Deere 333G Track Loader (A63111)
2018 John Deere...
