tractorshopper
Veteran Member
When I brought my baby home, the grapple had already been installed and was working perfectly. I used it a bit, then removed it. A couple weeks later, I put it back on, and it didn't open and close right away. I thought this was strange and was going to call my dealer, but after about 10-15 minutes, it started working and worked perfectly.
I used it a day and took it off and haven't had a need for it for several months, so it's been off. Saturday, I hooked it back up and it would not work again. Same as before; all FEL controls worked fine upon hooking it up, but the grapple wouldn't open or close after repeated attempts to cycle it. Probably played with it for 15-20 minutes including checking wiring etc. Finally stopped messing with it.
Texted dealer Monday and told him it wasn't working. He said bring it in. I went home early and hooked up trailer. Got on tractor and loaded it on the trailer and by happen stance, hit the open button and it worked perfectly. Texted back with a nevermind, but I don't understand what the issue is as to why it takes a while before working every time I connect.
Is this normal? My loader goes on and off a lot and it never hesitates when hooked hooked up. Why would my grapple do this? What should I check for?
This is a LP SGC0548 on a BX 2370-1. It has a diverter type valve hooked into the power beyond.
