ElmosBoy
New member,
Been lurking around for a few weeks, since buying my 2555 Mahindra!!!!). I have had some issues with my .8 acre, 7'-14', pond recently and just wanted to ask a few questions to see if anyone can offer some insight. :confused3:
I have an 8" vertical drain pipe that I assumed connected, via elbow to a horizontal 8" pipe that travels under my levy, out to a spill area for drainage. All of that assumption was correct except for the elbow...It ties into the horizontal pipe via a T...AND a ten foot section of horizontal pipe heads back toward the middle of the pond, as well as the 74-80 foot section that goes out to the spill-area. Now for the rest of the story.:confused2:
Had a clog, pond got REALLY high, my wife passed away on 12/17, so I was tied up with other matters & didn't notice until water was covering the deck of my dock. Friend of mine & I begin the process of "Unclogging" the drain pipe. We start from the spill-way end & pvc-pipe/pressure wash back up the length of the horizontal pipe under the levy. We encounter several blockages, (Feel like Blockages) as we push the cleaning device into the drain-pipe. We think we have it working, but the flow of water seems far inadequate for size of pipe.
We take another run at the pipe, just with the pvc push rod & VIOLA!!:cool2: Water comes forth in a big way and the vertical pipe is soon creating a whirlpool!!! :dance1:Life is good, we move on with our lives...
Until 3 days later, my daughter asks why the pond looks so ugly:confused2:....Because it has no water, or almost none...We discover that there is this section of pipe at the T, where the vertical drain pipe is that heads back into the pond...The only thing I can assume is that we managed to knock an end cap off of the pipe, during our cleaning effort, & allowed the entire pond to drain, except for 3-4 feet of water...
I have provided the owls, local coyotes, foxes, & whatever else shows up a smorgasbord of catfish & brim in the wet-lands my pond spills into...But even more importantly, I have to pray for rain & a quick refill of my pond, as it is the broader heat-exchanger in my "Surface Water Geothermal Heat Pump System", & problems heating & cooling my home are inbound if I don't get back some of the temperature exchange media, (Water), I inadvertently drained into the swamp...
All that to ask, why in the world did the Previous Owner run that 10' section of pipe back into the pond, t'ed at the vertical drain pipe??? Was it there to provide for complete drainage by introducing a long & strong enough push, thru the horizontal drain section, (Which I would have thought near impossible to force off against the pressure of that millions of gallons of water pushing back against it)...Or what?? Ideas or questions, I believe I have the pipe recapped, with a make shift cap, (You'd be surprised how few companies sell 8" pvc fittings on a Saturday in Southeast Georgia)...And have regained 10"-12" of water in 24- hours. Again any thoughts would be appreciated, sorry for the novel, but thanks in advance for ideas.
