Strange BX electrical problem
   / Strange BX electrical problem #1
DenisM
Bronze Member
Harford County, Maryland
Looking for one now.
I have a BX 1500. Today when I started it up I noticed my head lights were on but the switch was in the off position. Turned the switch to on and the lights went off for a few seconds then came on. Turned the switch off; the lights went off for a few seconds then came back on. Any ideas what's going on?? They now do this all the time. Only way to shut then off is pull the fuse.
Also noticed when I use the turn signals, either side, one side flashes but the other side will stay on. Is this normal?? I really don't remember them working like that.
   / Strange BX electrical problem #2
Maybe the switch is just loose in its mounting; or maybe the whole switch is bad.....or just corroded and needs cleaned up and tightened. Sounds like Gremlins at work here......good luck.
   / Strange BX electrical problem #3
On my BX, I think thats the way the turn signals work. I also would try and clean up the headlight switch.
   / Strange BX electrical problem #4
Sounds like water in the switch to me. I've had it happen several times on mine. Do a search here for possible fixes, other than keep it dry of course!
   / Strange BX electrical problem #5
x2 you got water in the switches. seek and you will find lots of posts on it.
I replaced mine with boat switches. The blinkers would flash for days any time the dash got wet.
   / Strange BX electrical problem #6
x3... water related switch malfunctions are well documented.
Kind of surprising for equipment that may be left outdoors.
Some have up graded to after market marine grade rocker switches and others avoid getting the switches wet.
I think someone even went to the trouble of drilling little weep holes and you can always blow them out with some compressed air...
I'll check the switches for water in the morning and post what I find. Tractor is stored under an open front shed. We we hit by Irene over the weekend and there was a lot of wind blown rain so the water in the switch makes sense.
Took the head light switch apart and found some dirt and moisture under the contacts. Cleaned everything up and it's now working properly.
Thanks for the help.
   / Strange BX electrical problem #9
Good you are on top of it... others have traced dead batteries to wet panel switches...
2023 DONDI DBR/75 S LOT IDENTIFIER 52 (A53084)
2023 DONDI DBR/75...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
1986 ASPT 30ft S/A Pole Trailer (A51692)
1986 ASPT 30ft S/A...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2023 JOHN DEERE 3033R LOT IDENTIFIER 83 (A53084)
2023 JOHN DEERE...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
