Strange accident this morning
   / Strange accident this morning #1
orezok
Elite Member
Mojave Desert, CA
Kubota B7800
On my way to work this morning I come across this accident. First I come across a sedan facing backward on the right shoulder and stuffed into a bank. Looks like they had to cut it open to get the driver out. then there was a debris field that extended 100 yards and I couldn't figure out what the debris was, and on the right shoulder is a dually towing a 24' to 28' flat bed loaded with empty pallets to about 8'. Some were in teh roadway just before the trailer.
CHP reports that the car swerved to avoid pallets and rolled it. The strange part was the debris field past the rolled car.
When I go by the truck on the shoulder, I see that there were NO axles or tires under the trailer. It was sitting flat on the ground.
Could he have lost both axle's?
   / Strange accident this morning #2
If something gave way like the load levelers between the axles it could have. Or if one failed the other could fail instant from overload.
Chris
   / Strange accident this morning #3
Maybe a sliding tandem????
I have run service calls on semi's that the spring broke holding slider pins in and stop blocks on frame broke when they hit the brakes.
2025 CFG Industrial M-AG (A50123)
2025 CFG...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
(APPROX 20) 2" X 3" X 49" TUBING (A51247)
(APPROX 20) 2" X...
2010 John Deere 200 Seedbed Finisher (A53117)
2010 John Deere...
(2) COLUMN PROTECTORS (A51248)
(2) COLUMN...
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
