Strange 3000 20 series Cruise behavior?
   / Strange 3000 20 series Cruise behavior? #1
orlo
Platinum Member
Guildhall, VT
JD 2305/JD 4720 cab
Hi:
Today on my 3320 I was using the automotive cruise control. This option is new to me but I have used it once before and it worked fine.
Today while using it (it was cool out, in the high 30's) it was fine, then after a while the decellerate key seemed to not work. I'd hit it and eventually it would work. What was weird is this. More than once I'd hit it a bunch of times, then when it would finally work it would decellerate an amount that seemed like the total times I had pressed the key. Maybe it's just a loose wire harness or something but this behavior seems weird. I had no issue with the accellerate side of the same button.
Has anyone else had weird issues like this?
   / Strange 3000 20 series Cruise behavior? #2
I have not. Was Loadmatch on? Does that make a difference for you?
I tried with and without loadmatch on. Same thing. Was inconsistent though, sometimes it would work fine.
   / Strange 3000 20 series Cruise behavior? #4
Push on the switch and watch your speed indicator. If I want to go down or up several settings I press the switch,watch the speed and then when the speed changes press it again. Maybe you are pressing it and not giving it time to react. Then when you press it several more times it catches up all at once.
2025 60 Gallon Poly Diesel Tank w/ 12v Pump (A48081)
2025 60 Gallon...
2014 VOLVO VHD (A50854)
2014 VOLVO VHD...
2025 K0520 UNUSED Welded Wire Mesh Roll (A50860)
2025 K0520 UNUSED...
2017 Ford Explorer AWD SUV (A48082)
2017 Ford Explorer...
2007 Chevrolet Impala Sedan (A48082)
2007 Chevrolet...
2001 Sterling L7500 Heil 12Yd T/A Dump Truck (A48081)
2001 Sterling...
