Straight electrical grinder
   / Straight electrical grinder #1
czechsonofagun
Elite Member
Old Dominion
Kubota B1750
I got this straight electrical grinder, Black and Decker I believe, it is old and the name is scratched bad.
It has no wheel or wheel cover on it, the anchor is 3/8", anybody is familiar with similar one? It warns against using a wheel not designed for 4500rpms, which should not be problem today, but every grinding wheel I found locally has a bigger hole. I am guessing 4-5" wheel is maximum it should take, but nothing came with it.
It looks sturdy and well built with full aluminum casing and from outside accessible brushes and overall nice piece of power tool. I was thinking adopting it to my lathe as tool post grinder, but due to the mass of the motor it would have very limited use. Now I am thinking just use it along my Makita 4 1/2".
Opinions?
   / Straight electrical grinder #2
Keep looking for grinding wheels as you will find some brands will come with sleeves (usually plastic inserts) or bushings to step down to your needed 3/8".
With appropriate bushing inserts all you need is then a couple of washers hold that grinding wheel in place.
You might have to go to an industriel supply house or again try a web search.
They exist as I have some at home.
   / Straight electrical grinder #3
Take a look at McMaster Carr McMaster-Carr alot of the dewalt stuff was was the old Black & decker ind. line,the largest wheel is 4" McMaster-Carr If you use a larger wheel and you get it caught you might break or bend the shaft. At one of the places I worked at the had the bigger B&D that had a 5/8 shaft w/6" wheel.
   / Straight electrical grinder #4
You have a lathe, you can make an adapter for the angle grinder wheels.
Etnyre 2000 Gal Asphalt Dist. Truck (A47477)
Etnyre 2000 Gal...
IR SDLGC80 Electric Golf Cart (A53316)
IR SDLGC80...
2018 Ford Transit Van, VIN # 1FTYR2CG5JKA96646 (A54865)
2018 Ford Transit...
10ft X 5ft Livestock Corral Panel (A55758)
10ft X 5ft...
2017 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A55788)
2017 Chevrolet...
2019 CATERPILLAR 259D SKID STEER (A52705)
2019 CATERPILLAR...
