Backhoe Storing Backhoe
   / Storing Backhoe #1
2YD
Bronze Member
East Metro MSP
With low rate financing (0%) I've decided to go all in and get the backhoe that I'd probably being buying down the road anyway. That said, I am wondering how a JD 375/485 is stored when not attached to the tractor, and by that I'm wondering if its tippy, needs to be chained to the barn walls, amount of room it takes up etc...Safety First
   / Storing Backhoe #2
Good move on the backhoe purchase! I think you'll be surprised at the number/kinds of jobs you'll find for it.
I've had 2 hoes now in the past 4 years. Neither are/were tippy if you've followed the owner's manual instructions for removing/storage.
I use old lumber scraps (green treated 4x6 and 4x12) under the bucket and the stabilizer feet to increase the surface area support and to help avoid the possibility that one side might sink a little more than the other (tippy...). Helps to keep the rusting to a minimum, too.
Since the boom and dipper are somewhat extended (and stabilizers) the space requirement is considerable (think... another tractor-size space). I just park it out of the way and double tarp it.
AKfish
   / Storing Backhoe #3
I set my 448 on a steel cart with casters to roll around the shop.
John
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A52128)
2022 Quick Attach...
UNUSED FUTURE SKID STEER HYD MIXING BUCKET (A51244)
UNUSED FUTURE SKID...
(9) 2 PLUG VALVES (A52472)
(9) 2 PLUG VALVES...
2018 RoGator 1100C (A52128)
2018 RoGator 1100C...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51694)
2015 Toro Multi...
2018 ATLAS COPCO V4 PORTABLE S/A LIGHT TOWER (A51243)
2018 ATLAS COPCO...
