Storage in cold areas
   / Storage in cold areas #1
BlacknTan
Platinum Member
Adirondacks of NY
Kubota B-7800
Does anyone here who lives in an area that experiences temps to -40 or so ever run your coolant over 50% for more freeze protection? I realize that going over 50% decreases the viability of acting as a coolant.
My B-7800 sits in an unheated garage, and the outside air temp often goes to 40 below in February.
My dealer in this area say's he's never had a problem with tractors sitting outside in these temperatures..
Any thoughts???
   / Storage in cold areas #2
I'm right across the lake from you at 1500 feet in Vermont. Similar weather. Never had an issue running 50%. Much more likely to have issues with condensation in the fuel tank if it's not kept full, or diesel gelling if no conditioner is used.
Pete
   / Storage in cold areas #3
Hi Black:
Antifreeze ratings such as freeze protection to -40 degrees are what might be termed relative. A mixture of antifreeze/water good to -40 degrees stays liquid till then, below this it still doesn't freeze, but turns to a kind of slushy liquid that still offers freeze protection. It never really freezes solid. You are still safe.
The jug of Walmart Super Tech antifreeze I have, shows that one might do a 70/30 mix, antifreeze/water which gives protection to -84 F. I think that this figure is rather academic since we don't approach this and because of the slush factor.
100 miles east of you we haven't seen colder than -26 F this winter, that was last week. But Island Pond, VT , 20 miles north of us, had close to -40 same time. Not good for man nor beast. Channel 3 gives the Saranac Lake readings which are routinely this cold. No thanks.
simonmeridew
   / Storage in cold areas #4
I have alway's used a 70/30 mixture in all my vehicles and tractors.
Morooka MST 660VD Tracked Dump Truck  Only 30 Hours (A51039)
Morooka MST 660VD...
John Deere 570-A Motor Grader (A50860)
John Deere 570-A...
2017 Chevrolet Trax SUV (A48082)
2017 Chevrolet...
SpotWeld RockerRite 480V Arm Type Spot Welder (A50322)
SpotWeld...
20 Gallon Air Compressor (A50860)
20 Gallon Air...
2007 Dodge Durango 4X4 SUV (A48082)
2007 Dodge Durango...
