Stop Solenoid
   / Stop Solenoid #1
bentonmike
Benton Ky
Kubota BX25
Sorry guys, I know this is only my 2cd post, but does anybody have the part # for the stop solenoid on an 09 BX25...after reading EVERY post on this great website, I've figured out my problem. Thanks to everyone. Where is the best place to buy one? Dealership or online...Thanks again for everything...Mike
   / Stop Solenoid #2
While you're waiting for someone with actual information, here it is for a BX24: 16851-6001-3.
I DO NOT know if they are the same, but maybe this gives you something to work with.
Z.
   / Stop Solenoid #4
You can go here: Kubota Parts for Tractors and Equipment
Put in the Series, Model and Select Engine and your email address and they will email you the parts diagram for your engine. You can just look on the .pdf and make sure you get the correct part number. You'll likely also get a price.
Call your local dealer and compare their price.
   / Stop Solenoid
Thanks I'll give it a try...have a great one...Mike
   / Stop Solenoid #6
Messick's Tractor will send you a parts page with exactly the information you are looking for.
   / Stop Solenoid #7
My BX24 stop solenoid is probably the same, it is 16851-60013 with an update part number to 16851-60014 for $127.79.
Here is Messik's - Kubota Stop Solenoid Part #16851-60014
Gary:)
I found your post from a search because mine is acting up and not letting me cold start unless I manually open it first in the morning than it is OK rest of the day once it is warm. Already looked it up for myself.:D
   / Stop Solenoid #8
It's too bad Benton, KY isn't closer to Lexington. Central Equipment on Red Mile Road has an excellent parts department and charges comparable prices. Every time I go on line to find a good price Central Equipment does as well for my Kubota BX23, Honda tiller, and Stihl equipment. They are one dealer where the term 'stealer' doesn't apply. Hopefully if your dealer isn't as good, you can find one near you. If not, I read good things about Messicks on this web site.
ametcalf
(9) 2 PLUG VALVES (A52472)
(9) 2 PLUG VALVES...
J and L Cargo Express Shadowmaster Enclosed Trailer (A52748)
J and L Cargo...
3pt Disc Harrow (A50121)
3pt Disc Harrow...
Takeuchi TL150 (A50120)
Takeuchi TL150...
2018 Toro 72in Zero Turn Commerical Mower (A50322)
2018 Toro 72in...
P.T 1000 Gallon Supply Tank (A50120)
P.T 1000 Gallon...
