Stockpiling diesel
   / Stockpiling diesel #1
Indian Territory
New Holland PowerStar 75
I am a VERY small-time farmer. Probably better to say I am VERY large gardener.
Anyway, I use a small tractor and appropriately-sized implements to grow using large-scale, row-crop, conventional agricultural techniques (though we are organic). Sub-grade drip fertigation, plastic mulch, etc.
It's really just an all-consuming hobby. But in recent months the whole practice has given us some peace of mind as a hedge against times that seem to want to go bad. We are not preppers as such, but we do preserve/can what we grow (which is a LOT), etc.
Anyway, I have a couple concerns that perpetually niggle the back of my mind. One is the availability of water, should things go REALLY south.
But more concerning still is the availability of diesel. I have MS. This fact, plus the sheer size of my operation, makes it an impossibility to grow using an all hand-tool "peasant" approach. My health just can't keep up.
So my question is, how can I safely stockpile enough diesel to sustain operations in bad times, given that the small scale of my operation makes certain infrastructure additions (underground fuel storage, etc) financially and laughably impractical?
Thanks.
   / Stockpiling diesel #2
I 've never had any problems at all, keeping a several hundred gallon tank or even a drum of fuel out in a storage building, out of the weather, even for a year or more...
No additives added, I just start out with a clean drum and keep the water out of it.
SR
   / Stockpiling diesel #3
As Sawyer stated, keeping water out of the diesel is the key. It will store for a long time. But with the changing seasons comes different humidity and heat variations, that CAN cause condensation (not always visible) in your tank.
I have a 275 gal tank, and I put in some BioKleen (can get online or most auto parts stores) to add to the storage tank to prevent bacteria growth which will cause you all kinds of problems if it gets in your tractor.
For your situation, it sounds like you don't go thru a bunch of diesel every month, so a 55 gal drum should work for you. (get a plastic one). You can also pick up an inexpensive 12v elec submersible pump to pump the diesel from the storage tank into your tractor (check ebay). I fill up my 9 gal tractor tank in less than a minute with my pump.
   / Stockpiling diesel #4
I don't guess this is stockpiling but I keep two 55 gallons drums under a shed that I fill 3 times a year. I have read it will keep much longer. I do use additives. I use a biocide and lubricity additive during the summer and some anti gelling for the fall delivery. My pickup tube for the pump is up off the bottom so if it gets any moisture it should be safe. When my pump stops picking up fuel the drums have 5 gallons left in the bottom. I tilt them so I can get the last 5 gallons out in a can and inspect it for water then pour it in something that needs topping up. So far I have NEVER had any water in the final 5 gallons.
   / Stockpiling diesel #5
In many 3rd world areas, diesel is sometimes stored for years.
   / Stockpiling diesel #6
Where I live you are allowed to have a 500 gallon portable tank without doing anything special. Above that you need spill containment and inspections, etc.
Anyway, I just keep two twin wall 200 gallon furnace oil tanks full and the 100 gallon transfer tank on my truck. Only reason being is I'm tired of the oil company scams and I buy in the summer when it is cheap. Every winter without fail just before heating season starts, prices sky rocket and they announce there was a refinery fire, or the ships couldn't get in, or some other BS to justify their price increase.
Luckily we get quality fuel around here, so even buying it in the summer I have no winter issues down to minus 40. Even our summer fuel is treated. But depending on your climate and fuel quality it wouldn't hurt to put some conditioner in it. I always put some Howes in mine.
   / Stockpiling diesel #7
Figure out how much you use and go for a six month supply. For me that's about 40 gallons. I see no reason to have more than that on my place at any one time.
   / Stockpiling diesel #8
I have 2 semi trucks that I rarely use, I try to keep them full of diesel, that’s over 400 gal. Plus a couple of 100 gal tanks of red fuel hanging around.
   / Stockpiling diesel #10
If you have the ability to stockpile some, I see no reason not too. Diesel out here now is 2.45 ish.. gone up a fair amount since the nov implementation. It will be well over 3.00 by this time next year. ..and I think 3.75 will be easily reached in 22/23
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A52472)
2014 AMERITRAIL...
2015 DRAGON 137BBL DOUBLE CONICAL VACUUM TRAILER (A52472)
2015 DRAGON 137BBL...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52748)
Kubota 24in Quick...
2022 JOHN DEERE 410E II (A52472)
2022 JOHN DEERE...
2017 Bobcat S70 Compact Wheel Loader Skid Steer (A51691)
2017 Bobcat S70...
