still working on the MF 165
   / still working on the MF 165 #1
accordionman
wright city, mo.
KUBOTA L3000DT, FEL.
HELLO TO ALL,
we are still working on my friends MF165. we installed
a new power steering pump, but it did not improve the
steering. i looked in the pump res. and the fluid had air
in it. does this mean we did not bleed it properly? does
anybody have a suggestion for bleeding this system?
any comments, help or suggestion appreciated.
accordionman
wlbrown
wright city, mo.
   / still working on the MF 165 #2
Here is what Big Dean has to say about bleeding the pump.
"[FONT=Arial,Helvetica,adobe-helvetica,Arial Narrow]First we will start with bleeding the air out of the power steering system. You always fill the [/FONT][FONT=Arial,Helvetica,adobe-helvetica,Arial Narrow]reservoir with the engine running. After you have it full, turn the wheels from stop to stop several times to [/FONT][FONT=Arial,Helvetica,adobe-helvetica,Arial Narrow]disperse the air from the system. You may have to fill the reservoir a couple of times if there is a lot of air [/FONT][FONT=Arial,Helvetica,adobe-helvetica,Arial Narrow]in the system.This is done with the plug out"[/FONT]
   / still working on the MF 165 #3
accordionman said:
HELLO TO ALL,
accordionman
wlbrown
wright city, mo.
What was the steering doing wrong BEFORE you replaced the pump? What OIL (type/weight?) are you using in the steering?
HELLO TO ALL,
the power steering was not working. my friend just
bought this tractor from another party, and they said
it was not working. we did a pressure check, and there
was no pressure on the gauge. installed the new pump,
and this pump has no test port. would have checked the
pressure if possible, because i would like to know what it
was producing. my friend has bought the CD from big dean,
and has been in touch with him by e-mail. we will be bringing
the tractor to my place, (shop) because we will have more
tools, and comfort here, and the MF dealer is a short distance.
happy holidays to all, and good luck with all your dreams.
accordionman
wlbrown
wright city, mo.
2012 JOHN DEERE 10-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A52748)
2012 JOHN DEERE...
JOHN DEERE 7300 (A53084)
JOHN DEERE 7300...
2014 Kubota RTV-X900 4x4 Utility Cart (A50322)
2014 Kubota...
2017 Ford F-550 4x4 Enclosed Utility/Air Compressor Truck, VIN # 1FDUF5HT6HED32921 (A51572)
2017 Ford F-550...
W&A 3pt Ditcher (A50121)
W&A 3pt Ditcher...
2012 Chevrolet Malibu Sedan (A50324)
2012 Chevrolet...
