jlemon
Bronze Member
- Joined
- Nov 13, 2002
- Messages
- 71
- Location
- Stoughton, WI
- Tractor
- Kubota 3830 HST, 723 loader, HD QA bucket, 1 remote w/top cylinder
I stopped by the NH dealer to test drive the 35D tractor and liked the sloping hood, but didn't like the dual pedal arrangement. Next stop was the Kubota dealer, where I tried the GST and HST models, and really liked the pedal arrangment on the HST, as well as the tilt steering wheel (especially compared to the NH). The JD dealer didn't have a model available to try, but since they use the same dual pedal setup as NH, I decided on a Kubota, and hope to order one by the end of the month.
Next step was to visit several dealerships, and one that was relatively close to me had a clean shop and setup, stocked a large amount of Kubota parts, and was patient with this tractor novice. The prices he gave me while I was test driving the tractor seemed a little on the high side, so I'm in the process of getting quotes from other dealers.
While I had initially decided on a basic 3130 HST setup, I'm now starting to succumb to the siren call of "it's just a small step up..." and need a reality check. /forums/images/graemlins/smile.gif
A friend brought his JD 4310 and 6' cutter over to cut down some of the 8' thistles on my property, and happened to mention that he normally runs the cutter on his utility tractor, as he feels the JD bogs down and is underpowered to drive that size cutter. This has me worried, since our properties are the same size (40 ac), but mine is more hilly, and I was planning on running a 6' cutter on the 3130.
Should I really consider moving up a notch to the 3830? The rear wheels are further apart than the 3130, which seems to mean that correct sizing calls for larger than 6' implements, which in turn need larger tractors - IT'S ALL AN EVIL MARKETING PLOT!!! /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif
I have been following RaT's 3830 posts, but still am not sure whether a 3130 will do what I want. One dealer I talked to said that a 3130 will pull a 6' cutter, but if it were him, he'd go with a 3830. I'm not sure if this was honest advice or if he was trying to upsell. The other dealer I liked didn't try to lead me into a larger tractor at all.
Any advice to go one way or the other?
