Stihl MS250 floods crankcase when not running
   / Stihl MS250 floods crankcase when not running #1
Mathias NY
Bronze Member
Williamson, NY
Kubota M7060, Kubota BX 2350, Case DO, Case DC, John Deere B, John Deere H
Last fall my MS250 would run due to old gas. After cleaning the carb, it ran but tended to flood out when starting cold. Yesterday when I tried to start it for the first time in 2 months, the crankcase was filled with gas, which prevented the engine from pulling over. Has anyone else come across this type of problem before? I've worked on dozens of saws, but never had them flood when I wasn't trying to start them.
My first guesses would be a sticky needle valve and/or a bad crankcase vent. I bought the saw new about 6 years old and it has only seen about 8 tanks of fuel in that time, so a plugged vent seems unlikely. Does anyone have any other suggestions?
Thanks for the help.
   / Stihl MS250 floods crankcase when not running #2
Your fuel tank vent could be clogged and letting pressure build up in the tank and push thought the carb:confused3:
Be careful cranking it over with gas in the crankcase. You could bend a rod or bust a piston.
   / Stihl MS250 floods crankcase when not running #3
I have had sticky needle valves on motorcycles in the past, which allowed the fuel to flood the bowl, on a bike the needle valve is actuated by float height, so I think the needle valve would serve the same purpose on a saw monitoring fuel uptake, same principal, but a different design.
I typically use fine electrical wire strands for cleaning needles and small orifices on carbs if the spray doesn't seem to work.
   / Stihl MS250 floods crankcase when not running #4
It has too be a sticky or dirty needle valve or miss adjusted needle., Tank vent would not do that. Steve
JCT 72" SKID STEER QUICK ATTACH BRUSH CUTTER (A51243)
JCT 72" SKID STEER...
2016 Nissan Altima Sedan (A51694)
2016 Nissan Altima...
(8) 2 PLUG VALVES (A52472)
(8) 2 PLUG VALVES...
2021 ASV POSI-TRACK RT-120 FORESTRY SKID STEER (A51242)
2021 ASV...
Case-IH 180 Magnum (A50120)
Case-IH 180 Magnum...
2014 FREIGHTLINER 108SD WITH ELLIOT H110 CRANE/MANLIFT (A52472)
2014 FREIGHTLINER...
