Stihl Kombi Heads & TrimmerPlus Attachments
   / Stihl Kombi Heads & TrimmerPlus Attachments #1
arrabil
Veteran Member
Winterstown, PA
JD 4200 & X475
Anyone have the definitive answer as to whether or not TrimmerPlus attachments can be made to work with the Stihl Kombi engine heads? I've read yes and no.
I had the TrimmerPlus boom extension in the store today and it would not mate perfectly with the Kombi boom extension. The outer shaft fits but the inner shaft doesn't seem to. You can't turn one shaft with the other by hand after mating. Not smoothly like when they aren't connected anyway.
Pulling out both inner, square shafts and comparing them side-by-side it looks like the Stihl shaft is slightly smaller in diameter than the TrimmerPlus one.
Anyone actually using them together? Or tried using them together?
Thanks.
   / Stihl Kombi Heads & TrimmerPlus Attachments #2
Me too...If there is away to use the cheap attachments on the stihl I would like to know also. :anyone:.
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
Knapheide Service Bed (A50860)
Knapheide Service...
2003 MACK RD6885S T/A DUMP TRUCK (A51406)
2003 MACK RD6885S...
2015 FORD F-250XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-250XL...
2016 New Holland B95CLR Loader Backhoe (A50860)
2016 New Holland...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
