stihl fs85
   / stihl fs85 #1
jh60
craftsman2146
I am trying to fix a fs85. It idles ok but after it is run for a short period (30min) it will bog when given throttle. I can feather the throttle and get the rpm up but if I give it throttle without feathering it it bogs and dies. then it doesn't want to start back up. It sounds like a fuel problem. I have had the carb off and cleaned with carb cleaner and compressed air. As far as the primer on top of the carb, should I be able to blow through any of those orifices? I have replaced the spark plug. Fuel filter looks alright. Any thoughts on what I may be missing?
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
UNUSED CFG INDUSTRIAL 12EX-ATA MINI EXC ATTACHMENT (A51248)
UNUSED CFG...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51691)
2015 Toro Multi...
