Stihl FS80 starting problems
   / Stihl FS80 starting problems #1
Curtistex
John Deere
This is an older Stihl FS80. Right up front I want to say the engine was submerged in a flood. I emptied out the cylinder and it ran fine for about three tanks of gas. Then.. nothing. I noticed that the ignition wire was a little melted and then the replacing started. New coil and plug=strong spark. Engine appeared flooded new carb and fuel lines. The rings were brittle and breaking+new rings. I had a new muffler laying around so new muffler. The issue seems to be that the piston is not opening up the carb intake on the down stroke. When the rings were off it had full movement. Does this mean the cylinder is warped? Any suggestions?
CAT Skid Steer (A50322)
CAT Skid Steer...
2016 Crane Carrier Co. Low Entry T/A New Way 31ASL 31Yd Side Loader Garbage Truck (A51692)
2016 Crane Carrier...
1996 Timpte 46ft Hopper (A53473)
1996 Timpte 46ft...
2012 ADDCO Arrowboard (A52377)
2012 ADDCO...
2009 Lexus RX 350 SUV (A53424)
2009 Lexus RX 350...
2025 K1230 UNUSED (10) Wire Mesh Netting Rolls (A53117)
2025 K1230 UNUSED...
