Hey I have a Stihl FS460 forestry saw. I was cutting down some trees today when the blade stopped spinning, the engine would rev as normal. I took the part that the blade attaches to off the shaft, I couldn't see anything wrong except for the shaft was in too far. The shaft was not meshing into the pinion gear in the head so I pulled the shaft out some and put it back together. It seems to work ok now. My question is should I be able the pull the shaft out and it will stop, how is it attached to the clutch?
