stihl fs 55 rz trimmer wont run wide open, and floods out.
   / stihl fs 55 rz trimmer wont run wide open, and floods out. #1
Hersheyfarm
Veteran Member
NE ky
I have had this thing for almost 10 years with no probs at all till now. It flooding out and not hitting top rpms. Now it will not hardly run. I have cleaned spark arrestor, new plug, cleaned muffler, air filter. Took spark plug off and muffler and made sure no fluid in crankcase. It will start but will not hit hi rpms and will flood out. Carb is next on list but just checking here incase this is a common issue.
   / stihl fs 55 rz trimmer wont run wide open, and floods out. #2
You said you cleaned the muffler, and that would have been my first guess as to the problem. Are there a couple holes that you can twirl a twist drill bit down through to clean out the carbon? Has usually worked for me.
Any suspicion of the fuel and fuel mix?
   / stihl fs 55 rz trimmer wont run wide open, and floods out. #3
check the fuel filter and the fuel pickup line.
   / stihl fs 55 rz trimmer wont run wide open, and floods out. #4
At 10 years old,assuming you've done the required maintance on it all along,could be a cracked line or leak in around lines.
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
CASE 580 (A47477)
CASE 580 (A47477)
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
2020 BOBCAT T870 SKID STEER (A52705)
2020 BOBCAT T870...
2018 E-Z Beever M12R Towable Brush Chipper (A50322)
2018 E-Z Beever...
