Stihl brushcutter grease
   / Stihl brushcutter grease #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
Since I'm now the proud owner of a Stihl FS55, FS85, and FS250 I know I'm going to have to grease them.
Any word on how "special" the Stihl brushcutter grease is? Can I pump in almost anything that I use on my tractor etc?
To me it's a royal pain to have to keep track of small special purpose greases.
   / Stihl brushcutter grease #2
I'm not big on keeping special grease's either but I do buy the small tubes of grease for my Stihl trimmers. I have a FS80 and bought a FS100RX last week.
   / Stihl brushcutter grease #3
Greasing these things is not what you're envisioning.
In fact, forcing in too much grease will force some up the shaft (inside the tube) causing other problems. It doesn't take a lot of grease, and is not a daily task.
The Stihl grease is designed for the high temps and speeds encountered, AND the tube's spout fits nicely on the gearbox opening for a quick, no-pressure dosing.
I am just a long-time rural user, but I have an FS66 and FS250, used continuously on fence lines, blackberries and other nasty stuff.
Both spin string heads, but the 250 also runs big blades about half the time.
I've put countless hours on both since new- in fact, I bought the FS66 in the mid '80s. Neither has ever had any kind of drive train issue.
I think that qualifies as an endorsement of the Stihl grease.
   / Stihl brushcutter grease #4
If you put too much grease in them and water from cutting wet stuff gets up inside the gear casing the casing will freeze and bust. I've done that.
   / Stihl brushcutter grease #5
How much grease do you use? My FS 55 RC was 7 years old in March, I've been using Stihl's own tube of grease since it screws right into the machine and you don't waste any. And after 7 years, I just bought my second tube of grease.:laughing:
My local Stihl dealer was closed when I posted.
The manual says check every 25 hours of operation and apply up to 5 grams of grease. But looking it up on the web a tube (80 grams) should last me for 400 hours of operation. So I guess I should just go ahead and get a couple of tubes, because I know I'll lose one :)
One more specialty tool.
   / Stihl brushcutter grease #7
Seven years sounds about right for me too. A tube lasts a very long time. I'm always careful not to fill it all the way to the top of the bolt hole and leave an air gap. That's what the dealer told me to do after my gear case cracked.
:( Thanks
Yes, that's what I read in the manual. I like to learn from the experiences of others.
I've had my FS55 for about 3 years and probably 40 hours max and there is stihl plenty of lube.
   / Stihl brushcutter grease #10
:thumbsup:
Wow....thanks for info on forcing grease up the shaft. I've been using the Stihl grease on my 1983 FS81 brush cutter and have never had a problem. Think I'm on the third tube now but will be more careful about overfill.
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
UNUSED HURRICANE STAND ON SKID STEER (A52706)
UNUSED HURRICANE...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2001 CATERPILLAR 140H VHP MOTORGRADER (A51406)
2001 CATERPILLAR...
2014 Ford Escape (A50323)
2014 Ford Escape...
SCAN TO RECEIVE TEXT UPDATES (A52705)
SCAN TO RECEIVE...
