stihl 026 power lost
   / stihl 026 power lost #1
haroldy
near peterborough,ontario
kioti ck30,,front mount snowblower
saw seems to be losing power
any suggestions
resharpened chain didnt help
cutting poplar trees
   / stihl 026 power lost #2
Have you cleaned the air filter?
   / stihl 026 power lost #3
How long have you owned/ used this saw? have you checked the condition of the plug and gap?
What type oil have you been using? and what is the ratio mixture?
Sthil products are temperamental and need the stihl brand oil with a 50:>1 mix in order to run at best performance,
Most every 2-stroke engine I have will use the cheap oil mix 32:>1 but the stihl pack blower I have has to be feed with the "special formula" stihl brand oil and @ 50:>1 trying to mix the bargain oil @ 50:.1 can result in Galling the piston and eventually lower the compression of the cylinder, which could also be a factor in your case,
I've tried using the mix I use for my other tools Poulan,Homlite,and crapmans, into the stihl and even though it will run in it, is as you stated seems to loose power, Which does make since
when it is trying to burn off more oil then should be,;)
Just a thought!:cool:
Examples of the mixing ratio
For a mixing ratio of 1 : 50 you need 5 litres of petrol and 0.10 litres (100 cmウ) of STIHL two-stroke oil.
Petrol quantity STIHL two-stroke oil
1 : 50 Other brandname two-stroke engine oils
1 : 25
Litres Litres cmウ Litres cmウ
1 0,02 (20) 0,04 (40)
5 0,10 (100) 0,20 (200)
10 0,20 (200) 0,40 (400)
15 0,30 (300) 0,60 (600)
20 0,40 (400) 0,80 (800)
25 0,50 (500) 1,00 (1000)
   / stihl 026 power lost #4
Haroldy; can you give a little more info, ex; how old, what is happening, last time serviced{plugs air filter} overall shape of saw................. You may have a bad fuel line or {??} with the ethanol they mix in the fuel today it raises heck with these small engines. I use Marvel Mystery oil in all of my gas and so far it seems to work. If you're bar is out of wack it could also cause issue's. Your clutch can also cause problems, there are many possibilties, we need more info.
As far as the oil goes I have never used the stihl oil and have NEVER had an issue with my saws. I use a common grade 2 stroke oil and have for many years, the only thing I have ever had to do with my saws are change a plug, clean filters, change normal wear and tear parts{chain, bar, etc}. I run 2 stihl saws that allways start on 3-4 pulls or less, I use them for land clearing, fire wood{40 face cord per year or more}, and logging for a small mill.
   / stihl 026 power lost #5
Try Forestry Forum/ chainsaws and search the archives. Amazing amount of info.
   / stihl 026 power lost #6
Also there is a new Chainsaw Repair .createaforum just for chainsaw repairs just like this.
2016 FORD F-450 9FT SINGLE AXLE DUMP BODY (A52141)
2016 FORD F-450...
(3) 8' High Pole Swinging Gates (A50515)
(3) 8' High Pole...
Wolverine Mini Skid Steer Auger Drive & Bit (A50514)
Wolverine Mini...
2014 BMW 320i Sedan (A50324)
2014 BMW 320i...
Crate of New Hydraulic Hoses (A47384)
Crate of New...
2014 Ford E-350 Cargo Van (A50323)
2014 Ford E-350...
