Stihl 026 hard to pull
   / Stihl 026 hard to pull #1
timsch75
Houston TX
'48 Ford 8N, JD GT235
I bought a used 026 recently. I have not had much luck with it starting. I have managed a couple of times to get it running, but it didn't seem right, so I rebuilt the carbs to put in a new diaphragm.
Trying to start it today, I had no luck. I've not yet looked into all of the possible problems, but there is one thing I'm troubled by regardless, and that is how hard it is to pull the starter cord. It is not the PRO model, so it has not decompression button, but I see from other posts that many people don't use this feature anyway. I don't mind cranking away while troubleshooting, but at this rate I'll wind up with elbow problems to go with saw problems.
What can I check to see if this thing is pulling correctly?
   / Stihl 026 hard to pull #2
Pull the spark plug and see how it cranks then. Report results.
plug pulled - easy to pull cord. All resistance due to compression??
I do have spark. I do not have new ethanol free gas/oil mix. My mix is about a year old. My new Stihl line trimmer works with it. How long before gas goes too stale for use in these saws?
I have not pulled the muffler to look for scoring.
I did clean the air filter and am letting it dry overnight.
   / Stihl 026 hard to pull #7
Year old? WAY past being useful. Dump it, get fresh mix. Always shake the mix before putting it in the saw and shake the saw prior to starting. Did the saw start prior to buying it?
There is also a fuel filter in the tank which should be replaced periodically. Hard to pull cord could be related to high compression, cylinder condition, etc, BUT it pulls easily when the spark plug is out. Removing the muffler and checking condition of piston/cylinder walls is prudent too. How much did you spend on the saw?
BTW, you'll destroy your line trimmer too with stale gas/mix.
Use ethanol free gas and Stihl's Ultra mix oil for every 2 cycle you have. Toss the mix after 3 months max.
   / Stihl 026 hard to pull #8
I'd also check the spark arrester screen in the muffler to make sure it's not plugged with carbon deposits.
   / Stihl 026 hard to pull #9
Why in the world would you try to use 1 year old gas?
   / Stihl 026 hard to pull #10
With old gas I bet your fuel filter is clogged up.
They generally have some felt as part of the filtration and that clogs easily especially with ethanol.
Fish the filter out of the tank with a wire hook and change it.
You might also discover the fuel pickup line rotted out by ethanol as well.
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A52128)
Neckover GL24-2-7K...
2018 CATERPILLAR 320GC EXCAVATOR (A51242)
2018 CATERPILLAR...
198921 (A51243)
198921 (A51243)
CASE 586H STRAIGHT MAST FORKLIFT (A51242)
CASE 586H STRAIGHT...
2015 CATERPILLAR 305E2 CR EXCAVATOR (A51242)
2015 CATERPILLAR...
2019 KOMATSU WA380-8 LOADER (A51242)
2019 KOMATSU...
