Stiff 3-pt control on L39
   / Stiff 3-pt control on L39 #1
kolmstead
Ridgecrest, CA
Kubota L2950DT and L39 TLB
The 3-pt. control lever on my L39 is very stiff. Didn't notice until I removed the backhoe and installed the 3-pt. hitch arms. The lever drags against one side of its slot, but I can cope with that by pulling the lever to the opposite side. I squirted a little oil on the point where the control rod enters the 3-pt. housing, but that didn't help much.
I was trying to use the 3-pt. hitch with a rear blade today to grade a driveway, and found that I had to slap the control lever to make it change position. Needless to say, the driveway wound up looking pretty rough.
My old L2950 3-pt hitch control got pretty stiff years ago, but oiling the point where it entered the 3-point body smoothed things right out. To do a good job with a rear blade or box blade, I need the control lever to move smoothly. Any suggestions?
-Karl
   / Stiff 3-pt control on L39 #2
My L35 lever is stiff also. Don't know why, but my particular machine never used the 3ph controls until I bought it - so I assumed it was stiff from non use.
I'll try to remember to remember to ask the dealer. Also, I have the shop manual so I'll look at that too.
   / Stiff 3-pt control on L39 #3
The 3 pt lever on my B-26 is also very stiff, it makes it very difficult to fine tune, let me know if you find a solution.
   / Stiff 3-pt control on L39 #4
My 3 point lever was very stiff on my JD 2520.
when it was new. i did oil all the linkage to all connections.
and now its smooth as silk.
Chris....:)
2015 Kenworth T880 QMC 8060R 50 Ton Tri Axle Crane Truck (A60460)
2015 Kenworth T880...
Tandem Axle Rear Trailer Frame (A55851)
Tandem Axle Rear...
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52707)
2015 JOHN DEERE...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
FORD F550 SUPER DUTY SERVICE TRUCK (A52707)
FORD F550 SUPER...
