STIFF 3 POINT ARM CONTROL IN 4520 CAB
   / STIFF 3 POINT ARM CONTROL IN 4520 CAB #1
jdhopf
2007 JD 4520(cab)
I have a 2007 4520 John Deere with 250 hours on it. I tried using the 3 point arms and the control inside the cab seems to be pretty stiff. Doing any kind of grading work that needs to have precise grading seems to be a challenge. I lubed up the cables and linkage on the tractor but it did not seem to help. Any ideas out there would be greatly appreciated. Thanks
   / STIFF 3 POINT ARM CONTROL IN 4520 CAB #2
I would inspect the cable for kinks, if you find any that is likely your problem. If it appears to be okay then try the following.
I would disconnect the cable at the valve under the cab and see if it is still stiff. This will indicate whether the cable or the valve is the problem. If still stiff them disconnect the cable from the joystick. If the joystick moves freely then get a new cable to install and make sure there are no kinks or sharp bends in this when installed.
   / STIFF 3 POINT ARM CONTROL IN 4520 CAB #3
I had the same problem on my 2007 4720. I went through and loosened the linkages and it seemed to help a bit. I think it is a design flaw on the older cab tractors. I traded in my 2007 for a 2011 and the problem isn't there anymore.
I didn't think they changed anything on the cab tractor from 2007 to 2011. What linkage did you loosen on your tractor, inside the cab are outside on the linkage in the back of the tractor. Thanks for the help
   / STIFF 3 POINT ARM CONTROL IN 4520 CAB #5
It was a while ago, but I loosened a few of the nuts outside underneath the tractor. I just had my daughter sit in the cab and rock the lever back and forth (engine off of course) and I loosened the linkage nuts. I'm not sure if this is considered a qualified JD maintenance operation, but it was annoying as **** to me too. It was nearly impossible to get a subtle adjustment to my landscape rake until I did this. Maybe the 2011 had this adjustment already made, but it is way smoother than my old 2007 even after the adjustment. Good luck!
   / STIFF 3 POINT ARM CONTROL IN 4520 CAB #6
Had this same problem on my 3320 a few years back. Should be a thread about it, but after careful inspection I found a nut under the cab that tightened and loosened the friction plate to hold the lever in position. Never had a problem since and can move mine easily with precision. If you can't find it PM me, have wrote it down somewhere just in case or I'll look under mine.
   / STIFF 3 POINT ARM CONTROL IN 4520 CAB #7
Yep, that sounds like what I did. Good to hear that I didn't do something stupid!
CASE INTERNATIONAL 695 TRACTOR (A51406)
CASE INTERNATIONAL...
GODWIN CD150M DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150M DRI...
Ford F550 Dump Truck (A47384)
Ford F550 Dump...
2017 FORD F550 XL SUPER DUTY BUCKET TRUCK (A51406)
2017 FORD F550 XL...
UNUSED PROFESSIONAL X2600A ELECTRIC CONCRETE MIXER (A54757)
UNUSED...
UNUSED WOLVERINE PFF2-13-45W PALLET FORK FRAME (A54757)
UNUSED WOLVERINE...
