sticky gas pedal
/ sticky gas pedal #1
jam2004
central NJ
Kubota BX 2230
A few weeks ago, I noticed my 2230 (35 hours) would continue forward a couple of seconds after removing my foot from the pedal. Now, it's also happening in reverse. Is this due to the unorthodox single pedal design (it never happened on my old, dual-pedaled Deere)? Any solutions?
/ sticky gas pedal #2
Take it to the Dealer, It is obviously still under warranty.
IF You do a search on sticky hydro pedal You will see more than You want to on the subject.
/ sticky gas pedal #3
There have been other threads on this exact same thing in the past. Sorrry...I did not book mark them... /forums/images/graemlins/blush.gif
I had something similar happen on my BX2200 and simply spraying the linkage with some lubricant changed this from a drifting stop to an almost neck snapping stop when I lifted my foot off the HST pedal.
You could try lubricating the linkage and see what happens. Others had to do more...I don't remember the details. A search might turn up those threads.
Try a spray lube of sume kind. I just might work for you. It did for me, almost to the tune that for a while I wished I had a bit of drift when I took my foot off the directional pedal. The lube made that much difference.
Your milage may vary. Worth a try though. Simple fix if it works.
/ sticky gas pedal #4
My 2230 has a zerk on the pivot. It faces the center and front of the tractor. I just hit 40 and lubed mine today. Hope its that simple /forums/images/graemlins/grin.gif
Steven
/ sticky gas pedal #5
Like another poster said, there is a grease zerk on the linkage close to where it connects to the tranny. I have the same thing on my B7300. I also have the same problem that you do. I have greased mine several times and it still continues to "stick." I have found that at lower RPMs it is a bigger problem. When I'm running at PTO speed it seems to perform a lot better.
/ sticky gas pedal #6
My BX22 did the slow to return deal and the "spraying till the cows come home" did not do anything. I used every grease, moly, silicone, etc and did not do a thing.
So I went to the dealer and he fixed in about 5 minutes. You just need to adjust the adjuster on the right hand side (by the rear tire)
Here is some reading:
Round#1
Round#2
/ sticky gas pedal #7
Mine had some bearings in the transmission bad, hope yours is not this same problem. I would think Kubota would have fixed this BEFORE now, since more than one had the problem.
There are a lot of places for dirt to get in, keeping in greased is the best solution for this, if it is in fact dirt in the linkage.
/ sticky gas pedal
I called my dealer today. They told me they'll have to take it apart. Although it's under warranty, they won't pay for pick up/delivery ($200). I might wait until it get closer to 50 hours to kill 2 birds with 1 stone. Is it ok to do the 50 hour check-up at 40 hours?
/ sticky gas pedal #9
why not start with something easy first. I bet it is nothing short of an adj.
/ sticky gas pedal #10
Mike,
I used your pictures and instuctions for the adjustment about a hundred hours or so ago. It did make the pedal stiffer in returning to neutral, but to be honest I don't think it changed the creeping any. I have just learned to live with it. Maybe I'll have it fixed under warrantee eventually. But your tutorial is the best place for any one to start the process of ellimination. Thanks for the link.
/ sticky gas pedal #11
I've tried the adjustment.. the lube.. the grease and have had it to the dealer twice and it still sticks!
John
/ sticky gas pedal #12
</font><font color="blue" class="small">( I've tried the adjustment.. the lube.. the grease and have had it to the dealer twice and it still sticks!
John )</font>
Gee one more time and it qualifys for the lemon law /forums/images/graemlins/grin.gif
/ sticky gas pedal #13
I would suggest You try the neutral adjustment if it is out of warranty.if it under warranty, then dump it in Kubota's lap.
/ sticky gas pedal #14
Ok, I figure try what is easier first, then go to the next step. Mine was the forward and reverse had to just be adjusted via the palte by the tire. Then he adj the tention on the spring (stiffness of pedal).
/ sticky gas pedal #15
Tomnky... I performed the neutral adjustment but it did not help. I've given up and will learn to live with the situation. The dealer had it for a week or so a few months ago. They said that they worked with Kubota to get the problem resolved. It is a little better but it still sticks sometimes.
John
/ sticky gas pedal #16
I agree a stay at the Dealership can be long as Mine set at one for six weeks with a defective valve.
Was this the adjustment where you jack one wheel off the ground to adjust?
/ sticky gas pedal #17
tomnky... Yes, that is the adjustment. It is very easy to check it. If the neutral adjustment is off you will get creep when there is no presure on the pedal. My problem is that the pedal does not return to neutral as quickly as it should. Sometimes you have to push on the pedal to get it to return to neutral. Once it gets to neutral the tractor does not creep.
John
/ sticky gas pedal #18
you could also adj the tenstion on the pedal too.
/ sticky gas pedal #19
gsxr1100.. I haven't tried shortening the spring. I will try that now that I have given up on the dealer.
John
/ sticky gas pedal #20
Outside of that, you did all that I know of.
Tufline Box Blade (A64047)
Tufline Box Blade...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 389...
John Deere S350 (A60462)
John Deere S350...
2022 Case 5550 Trident Spreader LOW HOUR (A63118)
2022 Case 5550...
2016 FORD F550 CREW CAB SERVICE TRUCK (A59905)
2016 FORD F550...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A61569)
2014 Glasstream...
