Sticking brake lever
   / Sticking brake lever #1
VashonFarmer
Bronze Member
Vashon, WA
Bobcat CT225
A few of us over on the Bobcat page are discussing a problem with a stuck brake on the CT line of machines, which is the same as your CK line. I tore into mine and found the issue is that the cam lever that is directly actuated by the brake linkage is jammed up where is goes thru the brake housing. I have not yet been able to get the lever out of its hole and I'm going to talk to a Bobcat service tech on Monday, but I'm curious if any CK owners have had the same problem.
   / Sticking brake lever #2
did you ever get this problem resolved? Mine is having this same issue
2013 FREIGHTLINER M2 TANDEM AXLE DAY CAB (A52576)
2013 FREIGHTLINER...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
Crosley 10ft Hydraulic T/A Dump Trailer (A50323)
Crosley 10ft...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
1985 Eager Beaver 9D0W Tri-axle Flatbed Equipment Trailer (A50322)
1985 Eager Beaver...
