stick tranny parts
   / stick tranny parts #1
klxfl1
Hi d3250
I need to fix the stick assembly that attaches to the gears in the transmission. Something has broke. My problem is I dont have a spec of the transmission to see how to take it apart, to order the part. Does anyone no where i can get this?
Thank you
   / stick tranny parts #2
If your Mitsu is like my stick transmission, you would remouve the six machine screws that hold the cover on the transmission.
Put it in neutral first (if you can) as that makes it easier to re-assemble, otherwise you can do it by hand once opened.
You might simply find that you have a bent fork or some wear that allowed the 'stick' to get stuck in the wrong place, or jammed between forks.
If wear on the shifter sometimes a bit of delicate welding can rebuild the shifter ball end.
Might even be simply a sheered roll pin that holds a shifter fork onto a shaft.
Good luck!
And welcome to TBN!
2019 CATERPILLAR 938M WHEEL LOADER (A60429)
2019 CATERPILLAR...
2014 FORD F-150 STX EXT CAB TRUCK (A60430)
2014 FORD F-150...
2024 YANMAR TL100VS SKID STEER (A60429)
2024 YANMAR...
2013 Nissan Juke SUV (A59231)
2013 Nissan Juke...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
4 Unused Montreal ST205/75R15 Trailer Tires (A55788)
4 Unused Montreal...
