Sterring problems
   / Sterring problems #1
Acking
Fulton, ms
575 DI mahindra
Hello all i need some help i have a 2000 model mahindra 575DI and i was runnin it the other day and three of the seven bolts in the sterring box broke i have talked to serveal people and im told that it is my pressure relief valve. The pressure relief valve in this tractor is supposed to be located in the tandom hydr pump i have taken the pump apart and have not found any sign of the valve. Am i over lookin it ? I bought the tractor used and am thinkin that someone has removed it. If that is the case can i add a pressure valve to this tractor without buyin a brand new pump? Please help im lost on this and cant find many people to talk to!!
   / Sterring problems #2
Every hyd circuit should have a relief valve.
Does your PS fluid come directly from the pump, or does it come from a splitter/divider, which may have a relief valve on it.
   / Sterring problems
Straight from the pump it is a tandom pump runs sterring and lift for implements no front end loader.
   / Sterring problems #4
Acking,
Yes, you can add a relief valve to the steering circuit.
UNUSED SDLANCH SDLGC ELECTRIC GOLFCART (A54756)
UNUSED SDLANCH...
BUSH HOG 2820 LOT NUMBER 125 (A53084)
BUSH HOG 2820 LOT...
2017 Ford F-150 (A55788)
2017 Ford F-150...
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
70pc 12ft.x 3ft. Grey Metal Roof Panels (A53424)
70pc 12ft.x 3ft...
CATERPILLAR D11T HI TRACK CRAWLER DOZER (A52705)
CATERPILLAR D11T...
