Sterring cylinder ?
   / Sterring cylinder ? #1
mefyj
Sunny Arizona
Kioti DK35
While greasing things the other day... noticed that the rubber was torn on the tie-rod end. While I was down there messing with the extra grease. I noticed that the shaft is loose in the cylinder. Not leaking oil but shaft is sloppy in the cylinder. Checke the other side and it is also sloppy but not quite as much.
What's the story on these steering cylinders? Is this normal or ?
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
CAT 973 (A47384)
CAT 973 (A47384)
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
