Steiner 525 disel
   / Steiner 525 disel #1
ernemats
Veteran Member
Bolivar, pa.
power trac 422, and agco-allis 5660, ,1845 power trac Greenworks CRT 426
My son has an older Steiner 525 that he is having problems with right now it will start up and run till he engages the mower or goes to move it then it almost stalls out. We put a new fuel filter on it , still no difference. Seems to be a issue with tractor not getting enough fuel, any ideas on where we should check.
   / Steiner 525 disel #2
Remove the fuel line from the filter housing that goes to the tank to see if your getting a good flow, next remove the fuel line to the injector pump and run the electric fuel pump (assuming it has one) to see if the pump is working as it should.. If you have a restriction it may be in the tank if not maybe your fuel pump is getting weak.. Just some simple things to check..
Did you bleed the system after you replaced the fuel filter?
New Holland 939 3 Row Corn Head (A50774)
New Holland 939 3...
2015 Nissan Sentra Sedan (A50324)
2015 Nissan Sentra...
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
Case International 585 Tractor (RUNS) (A50774)
Case International...
2017 Rogator RG1300B Dry Fertilizer Applicator (A52748)
2017 Rogator...
Club Car Electric Utility Cart (A51694)
Club Car Electric...
