Steering wheel crack repair?
   / Steering wheel crack repair? #1
2manyrocks
Super Member
The steering wheel on my YM226 has recently cracked leaving about a 1/8 inch gap. Any ideas how to fix it or am I stuck trying to buy a new one?
   / Steering wheel crack repair? #2
Don't know the details but I have read on some other sites that body filler works
   / Steering wheel crack repair? #3
Does your steering wheel flex when you pull on it or push on it ? If it does , you may consider putting a flexible crack filler in it like a black silicone or something like that. If you put a hard material like body filler, it will not stick very good and also will crack. Most all steering wheels have a metal rod inside and plastic coating to give it the shape and looks and not much more
Jim
   / Steering wheel crack repair? #4
Re: Steering wheel repair?
Just buy another one from one of the dealers on this site.
They dont cost very much at all.
:D
   / Steering wheel crack repair? #5
I'm not a bowler, but, I've heard the compound used to repair bowling balls works well to repair steering wheels.
thanks.
   / Steering wheel crack repair? #7
2manyrocks,
Body filler alone will not work for a permanent repair.
If youæ±*e budget conscious or just enjoy working and restoring parts for your Yanmar, I have had great success doing the following:
Remove and wash the entire wheel with Acetone (or denatured alcohol), clean the affected area with a wire brush thoroughly, wash again and mix and apply JB Weld or equivalent two part epoxy and let cure. Once cured, use 80 grit abrasive paper to cut, feather and shape the epoxy. Use a thin coat of polyester putty (body filler) skim coating that area (and any other scrapes and deep scratches) and finish sand with 180 and final with 320 grit paper. Prime and paint with a high quality aerosol paint (even rattle cans will work well).
My steering wheels have so far, lasted better than four years regardless of the elements and extreme Texas exposure from the sun.
Mark
   / Steering wheel crack repair? #8
JB Weld ROCKS! Key to usage is to allow plenty of cure time, preferably in a warm area. It dresses down pretty well afterwards.
I did some searching and saw that two part expoxy has been used to repair steering wheels on cars, but they were recommending a product from Eastwood. But if JB Weld will work, that's good enough for me.
   / Steering wheel crack repair? #10
Eastwood.com does sell a steering wheel repair kit. Works great.
Eugene
49" X 74" EXPANDED METAL RAMP GATE (A51247)
49" X 74" EXPANDED...
2020  FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2020 FREIGHTLINER...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A53472)
2017 Yale GLC050VX...
SPEECO SPLIT MASTER 15 TON PORTABLE WOOD SPLITTER (A51248)
SPEECO SPLIT...
UNUSED MOWER KING 72" HYD BRUSH CUTTER (A51248)
UNUSED MOWER KING...
2006 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F750 XLT...
