Steering shaft replacement on LK 3054
   / Steering shaft replacement on LK 3054 #1
Uglyhat
I broke the shaft coming out of the steering box (as described in thread "broken steering shaft, any used parts?"). Removing the steering box to have the shaft replaced appeared at first to be a straightforward procedure, but I've run into a couple hitches I'm not sure how to solve.
First, I can't get the steering box to come loose after getting the four bolts connecting the box to the transission casing. The box appears to be simply bolted to the transmission casing beneath, with no apparent mechanical interchange between the two. I've tapped 'firmly' but no harder with 5lb hammer and wooden block to no avail. I can find no other means of fastening the box to the transmission casing. I'm thinking either there IS a mechanical conncetion between the box and casing, or it should come loose with the appropriate force. The power steering lines are loose, no other wires or attachements.
Second, the splined stub of the broken shaft is quite stuck in the cast piece into which its inserted. Threads and a 19mm nut extend on the side opposite the broken stub, providing a great deal of force to pull the spilned shaft into the hole in the cast piece. I've soaked each side with PB blaster and pounded rather hard, but I didn't want to shatter the cast piece and it didn't budge.
So, am I missing something with the way the steering box is attached to the transmission casing, or do I just need to encourage the box more firmly with hammer and block? And how can I get the stub of the shaft out?
Any help will be greatly appreciated !!!
   / Steering shaft replacement on LK 3054 #2
I have a workshop manual for the 3054 and it says little about removing the unit from the transmission case. In the (general and separtion section) it simply states; 1. Remove the fuel tank after draining fuel. 2.Remove the power steering.
As to servicing the sector shaft, it appears you must remove 1.the column assembly,2.the steering shaft,3.the end cover,4.the valve assembly,5.the side cover which houses one end of the sector shaft. Then you can "tap out the sector gear shaft toward the side cover"
Pretty complete and thorough instructions, wouldn't you say? Kioti manuals suck. A total waste of $85.00 if you ask me!
OOPS !! I apologize for mistakenly placing this in buying/pricing ... will try to get thread moved without cross-posting.
2019 Ford F-550 Flatbed Truck, VIN # 1FDUF5GT5KDA27067 (A51572)
2019 Ford F-550...
(3) STEEL CARTS W/ WHEELS (A51248)
(3) STEEL CARTS W/...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2017 Case IH Magnum 380 ROWTRAC CVT Tractor (A53342)
2017 Case IH...
Unused Delta Crash...
