Steering problem
   / Steering problem #1
RandyS
CT and upstate NY
Jinma 204, Mahindra 2816, Prowler mini skidsteer
When using our Jinma 204 yesterday the steering was having a problem. I could at times spin the steering wheel around and nothing would happen. Then it would work fine again, then it would spin.......
Thank you.
   / Steering problem #2
You are having either a problem with the pump, low on hydraulic fluid or a seal out on your steering cylinder.You need to narrow it down first starting with the level of hydraulic fluid,is the 3-point working OK, if so it's not the pump.Keep us posted
Tommy
Affordable Tractor Sales
   / Steering problem #3
Hey Randy,
I know this is an old post, but I talked to someone today with the same problem as yours. Did you ever get it figured out/fixed?
   / Steering problem #4
Hey Randy,
1998 C6500 Chevy, 3126 Cat Engine (A52384)
1998 C6500 Chevy...
2016 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER TRUCK (A52141)
2016 INTERNATIONAL...
Brent 776 Grain Cart (A50514)
Brent 776 Grain...
1 Oliver Front Weight (A50515)
1 Oliver Front...
2023 Trailerman Gooseneck (A50514)
2023 Trailerman...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51694)
2015 Toro Multi...
