Steering Oil Line Leak
   / Steering Oil Line Leak #1
bmcqueen23
Houston County Texas
John Deere 4010
Just got my 4010 back from having some hydraulic work done on it. Looks like the mechanic put this oil line on, however it started leaking the other day as I was loading hay. I tried to tighten it up and its still leaking pretty good. Is there an easy fix for this? Or should I replace the line? The line is 187.25 on jd website so I'd like to try and save that. It is leaking underneath the fitting.
   / Steering Oil Line Leak #2
if the mechanic put on the line make him replace and pay for the line.
   / Steering Oil Line Leak #3
Not sure what line youare referring to but for this vintage is most likely a jic style fitting so line may be cracked and needs to be replaced. Depending on what line this is you can possibly get by w/ a mfg hyd hose. You will want to make sure you accuratly size so you don't restric flow. The line off of the pressure control valve is probably best replaced w/ another steel line.
2015 Ford F-450 Cab and Chassis Truck (A51692)
2015 Ford F-450...
John Deere 310K Backhoe (A51573)
John Deere 310K...
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52748)
2013 Doyle Dry...
2012 Kenworth W900 (HEAVY DUTY) (A52748)
2012 Kenworth W900...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
