cgmeyer77
I purchased a barely used NH Workmaster 35 (2014) with 180 hours on it and noticed a "growl" in he steering along with a significant vibration in the hydraulic pipes to/from the steering system. One of the pipes had actually cracked. I replaced the pipe, changed the fluid (waiting on a new filter) and the noise is still there. Particularly bad with weight in the loader. I figured it was air in the system and I tried the recommended purge by taking weight off the front axle and turning the wheel all the way left and right with a 5 second hold. Also changed out the gear oil in the front axle, and the engine oil. No luck, still bad vibration noise in those steering hydraulics. Its another cracked pipe withing to happen. Any thoughts/ advice would be appreciated!
CM
CM
