Steel Sleeves
   / Steel Sleeves #1
deerefan
Veteran Member
louisiana
1952 8N, 2005 JD 5103
According to the serial # on my new 2N project, the tractor is equipped w/ steel sleeves. Is there any advantage to these over the cast iron sleeves available later on?
   / Steel Sleeves #2
I think it was a wartime supply deal. I don't know if one is better than the other as these tractors have been going for a looooong time. later, Nat
   / Steel Sleeves #3
I don't believe it was a war time only deal.. unless we were at war in 39. The sheetmetal .040 steel sleaves were finally dropped and replaced with the .090 cast iron sleaves as they wore better. Same reason also why they went to 3 ring pistons instead of 4 ring... too much extra wear.
Many people have the block bored for the cast iron sleaves when replacing the sheet metal ones... though i *think* you can still get the .040 ones from places like Dennis Carpenter.
Also.. virtually impossible to know what type of sleaves you have till you pop it open... even if the sn range is a steel sleave.. you never know who has been in it these last 50+ years and may have swapped them over o the .090 cast iron sleaves.. or bored and fit custom sleaves.. or even ran it bare with OS mercury pistons.. for a few more CI at the expense of their block..
Soundguy
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A52377)
2013 Chevrolet...
Heavy Duty Jumper Cables (A51694)
Heavy Duty Jumper...
2008 Chevrolet Uplander (A51694)
2008 Chevrolet...
5420 John Deere Tractor (A52384)
5420 John Deere...
2018 Great Dane Freedom LT 102"x48' Flatbed Trailer (A50123)
2018 Great Dane...
2015 JOHN DEERE 310K BACKHOE (A51406)
2015 JOHN DEERE...
