Steel rack pics
   / Steel rack pics #1
JD Greg
Bronze Member
NW Iowa
currently 2008 JD X540. Looking at a JD 2305.
Joe 427 Vette:
Here are some pics of my steel rack.
I will give you the dimensions of what mine is.
For me, I wouldn't change a thing. Tall enough and long enough to get a 4x8 sheet of steel in the back. I have 3" steel swivel casters all around. Do Not use rubber casters, they will flat spot and you will have a hard time moving the rack around. I have moved mine several times without any problems. Sometimes, takes me longer to move the things that I have stacked around the rack, than it does to actually move the rack to where I want it. But, I rarely move it. Hope the pics help.
Here are the measurements:
1 1/4 x 1 1/4 x 1/8 sq tubing for the entire main structure.
1 x 1 x 1/8 sq tubing for the steel "holders", 6 inches long and spaced 6 inches apart.
the base measures: 8' long, 56" tall, 18" deep. 3"steel swivel casters mounted at all 4 corners, bolted to 1/8 steel plate which is welded to
1 1/4 sq tubing.
The rear uprights are 1 1/4 x 1 1/4 x 1/8 sq tubing. Each end upright is obviously attached to the end of the base, with the center 3 uprights being 24" on center.
   / Steel rack pics #2
Thanks for the pictures. Nice steel rack and great inventory. I went wider at the base because I have alot of short ( 2' or less ) pieces I want to organize. I had some 2x2 for the parimeter and bought some 1 1/2 square tubing for the uprights to run 3 6' pieces down the center with lateral bracing.
After viewing this I may have to ponder more on the overall design. I don't store any 4x8 sheets, just cut offs. If it gets any higher priced I may have to call it the gold rack !
2016 Kia Soul SUV (A55853)
2016 Kia Soul SUV...
2006 Chevrolet Impala Sedan (A54815)
2006 Chevrolet...
greenworks (A53421)
greenworks (A53421)
2007 International 4300 (A53314)
2007 International...
Utility Trailer (A52377)
Utility Trailer...
2014 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400 LB Crane Service Truck (A53422)
2014 Ford F-550...
