Steel hydraulic lines will wear through and leak on TC series
   / Steel hydraulic lines will wear through and leak on TC series #1
cdcole
Wisconsin
TC25D
Hello - just wanted to share with you something that you should check before it is too late. The metal hydralic lines that go from the loader valve and under the right side of the foot rest platform can rub on obstucting parts and can eventually wear through. Check yours. My TC25D needed a replacement hose this weekend. Easy repair but still a time waster. Good luck with your inspection. If rubbing ...consider a hose clamp and a piece of rubber or something.
2018 Ford Transit 250 Cargo Van (A51692)
2018 Ford Transit...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
TIRE TOOLS, BUNGIE CORDS, BALL HITCH (A53843)
TIRE TOOLS, BUNGIE...
2018 Ford F-250 4x4 Crew Cab Gooseneck Service Truck (A51692)
2018 Ford F-250...
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
2013 Ford F-250 Pickup Truck (A51692)
2013 Ford F-250...
