Steel Gate Post
   / Steel Gate Post #1
Believer
I'd like to set some 6" steel pipe posts in the ground in Kansas. I want to hang a 16' gate. I was going to do an "L" shape on each side of the gate, welding some horizontal pipe between the vertical posts. I have a couple questions. How deep should I set the post? Should I weld something onto the post below grade that would set in the concrete? Thanks.
   / Steel Gate Post #2
My experience is no matter how deep it is, it sags over time. My neighbor did something that worked. On the hinge side of the gate, the "gate post" is an assembly made of two posts set in concrete about 3' apart, with horizontal pipes welded between them, one at the top and one near the bottom. That creates a frame rather than a single post. It's similar to the way you do corner posts on high tension fencing if you're familiar with that.
   / Steel Gate Post #3
Beez is right for a heavy gate that long you will need to make a 2 post support with pipes welded in between as he described that will hold her up.:)
   / Steel Gate Post #4
If you put a brace across the top of the posts, they will stay in place and the gate won't sag. Of course the posts need to have 10' or better out of the ground for clearance.
   / Steel Gate Post #5
In Believers post, he says he is going to weld horizontal supports!
I would go at least 4' deep on the post. The "L" shape your talking about, is that 3 set post then the Horizontals? Should be a strong set if so, especially if your using a light weight store bought ranch gate.
I like Gary's thought on the entrance overhead pipe, but not really necessary if your doing it like you said, but would be stronger and looks good done right. If also I'd go at least 12' or more, never know when you need to get a cement or other truck in there.
   / Steel Gate Post #6
You must do a diagonal from the top of gate post to bottom of adjacent post, and a horiz across top. Horiz on bottom is optional.
larry
   / Steel Gate Post
I have another question about the concrete. Shall I buy the bags at Home Depot and use as is? Should I put any aggregate in? I'll also ask again about whether I need to weld anything onto the post that will be in the concrete. Thanks.
   / Steel Gate Post #8
Those bags will work fine as is. I always mix mine then pour, some like to put it in dry and add water. i like to know it's all curing at the same time with no doubts.
You dont need anything welded underground. Set your post and weld your horizontals and you'll be good for along time.
   / Steel Gate Post #9
Believer,
I used a 6"x6"x9' 3/8 steel post holding a 16' gate with no sag.
Put the post 4' in the ground inside a 24" hole filled with concrete. Using weld on hinges from King Architectural Metal:
USA Barrel Hinge. 1" x 2" Weld Pad, 1-3/4" Installation Gap, 5" H, 2.75 lbs
2 of these hinges have worked well for 4+ years no sag. They support like 500lbs each. Gate is like 250lb.
Might be overkill but it'll be there long after I'm gone.
Jaeger
   / Steel Gate Post #10
Thanks for the link
2011 Kenworth T300 Jerr-Dan 21WSRB Rollback Truck (A52377)
2011 Kenworth T300...
2018 Atlas Copco Pas200HF Diesel Dewatering Pump (A52377)
2018 Atlas Copco...
2015 Kia Cadenza Sedan (A53424)
2015 Kia Cadenza...
2023 CATERPILLAR 259D3 SKID STEER (A52705)
2023 CATERPILLAR...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
PALLET OF SCAFFOLDING (APPROX. 12 PC) (A52706)
PALLET OF...
