Oil & Fuel steel fuel lines ym240
   / steel fuel lines ym240 #1
jbrd
East San Diego County, Ca.
B7800 & Ym240
Has anyone replaced the steel fuel lines with lines other than the solid steel fuel lines, or where is a good place to find these lines? I tried Hoye - no luck. Thanks, jbrd
   / steel fuel lines ym240 #2
Unless the line is an injector line, I see no problem replacing with a flexible fuel line.
Just be shure that you have barbed fittings to connect and use automotive clamps to fasten firmly.
Also be careful of routing to prevent chaffing and clamp/tie the line to framework etc.
Also be shure that the line you use is 'fuel rated' and not big box store multi purpose plastic.
   / steel fuel lines ym240 #3
Try a Yanmar authorized parts dealer.
   / steel fuel lines ym240 #4
Brake shops fabricate steel lines all the time. I don't know if the pressures are comparable, however. Or try a hydraulic shop.
2024 JOHN DEERE 1025R LOT NUMBER 109 (A53084)
2024 JOHN DEERE...
John Deere Z915E Zero Turn Mower (A51573)
John Deere Z915E...
Hyster H225E (A47384)
Quick Attach Skid Steer Plate (A51573)
Quick Attach Skid...
2013 CATERPILLAR 320EL EXCAVATOR (A51246)
2013 CATERPILLAR...
