Steel Fence Posts - Drive or Set in Concrete?
   / Steel Fence Posts - Drive or Set in Concrete? #1
Ox 77
San Antonio
None
We just bought a few acres and are planning to fence it off. Going to use either 2 5/8" or 2 7/8" pipe for braces. Was planning to dig holes and set in concrete, but I talked to a fence contractor and he said to drive the posts (I have access to a driver).
Would be faster to drive. If I did concrete it would be 3 ft deep, 9 inch wide holes. While it's close to area I'm from and have fenced, the soil is completely different. It's real dark, rich soil, not many rocks. (I'm used to thick clay about 10 inches below the surface).
Would be good condition pipe, no used up oil field rejects. Also it's south Texas so frost heaves for concrete shouldn't be a factor.
And this would be my first fence using steel braces - only wood posts in my experience so far.
Anyway, do any of you have thoughts on driving vs concrete? Thanks.
   / Steel Fence Posts - Drive or Set in Concrete? #2
I’d set my corners, gates, elevation changes etc in concrete and drive the rest. Most don’t have access to the driver but few would spit on it if it was offered!! Enjoy it.
Basically, at 3’ deep in Texas, you can to about anything with them.
Btw- oil pipe is probably better quality steel than anything you can buy.
   / Steel Fence Posts - Drive or Set in Concrete? #3
I've only ever used T-133 fence posts. I think - JMHO - RNeuman has the right idea. Set in concrete at the high stress points and drive in between. You are fortunate - all your land is "tractor accessible". I used a manual post pounder to set the 670 T-post around my 80 acres. Mile and a half of five strand barbed wire fence - thank God that was 36+ years ago. With routine maintenance - my perimeter fence is still as good as the year I installed it.
I have a couple valleys and draws that are only accessible on foot. A couple other that I can get into on my ATP - if I REALLY need to. That makes four or five that there is NO WAY a tractor could enter or exit. I deliver fencing repair supplies to the lip of the valley or draw - its on foot the remainder of the way.
   / Steel Fence Posts - Drive or Set in Concrete? #4
I agree. I often use 4x4s set in concrete at corners and just driven steel posts in between.
Ralph
   / Steel Fence Posts - Drive or Set in Concrete? #5
Ox,
One thing to be careful is that there are different grades of used oil well pipe. Some it if gets pretty thin and will buckle when driven.
Good luck
   / Steel Fence Posts - Drive or Set in Concrete? #6
Always build good strong corners & gate posts, but the advantage of steel (I'm assuming T posts) is that they can be and work well just driven in saving a lot of effort & costs.
   / Steel Fence Posts - Drive or Set in Concrete? #7
A fence builder that I know told me that he did a test of doing it both ways and after waiting a week, pulling each one out to see which was in the ground better. He said the post that was pounded into the ground was the harder one to get out. I've never actually pulled a post out of the ground that was pounded in, but I have taken out quite a few in concrete and in my opinion, they are pretty darn hard to get out. Since I don't have a post pounder, and I don't want to spend the money on buying one, I just drill all my posts and set them in concrete. When comparing which way is stronger, I'm not sure that it really matters, both ways are very strong and commonly done all over the world. The bracing is where you either win or fail in fencing if the posts are in the ground deep enough. That is what you need to focus on the most. I also think that the big advantage to pounding the posts into the ground is the amount of time it takes. Pounding is going to be significantly faster!!!!!
   / Steel Fence Posts - Drive or Set in Concrete? #8
Follow up on what Eddie said. I've tried pulling driven T-133 steel posts and almost tipped my first tractor over. I had the post attached to the side of the bucket on the FEL. Went to a center pull with the FEL/bucket and it still made the tractor a bit light on the rear tires. Tractor was a Ford 1710. I pulled all the T-133 posts around the old garden site for reuse.
Got a 75 foot section of the fence line - going thru my "moat" - where I have to replace five T-133 posts every 5 to 6 years. Ground constantly wet - steel posts rust off right at the ground line.
Haven't found a real use for "short" T-133's yet - but the pile is building.
Thanks all. To be clear, not talking about T-posts. Either 2 5/8" or 2 7/8" pipe and just the end braces. I think I may go with the suggestion of concrete for the end posts and gate posts. But I might experiment with a run in the back and just drive everything and see how it holds up.
   / Steel Fence Posts - Drive or Set in Concrete? #10
That will be a good fence! Are you doing wire, boards etc?
2011 BEALL TRAILERS PNEUMATIC TRAILER (A45333)
2011 BEALL...
2013 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A44572)
2013 Chevrolet...
2015 Ford F-350 4x4 Utility Truck, VIN # 1FD8X3H67FEC72951 (A44391)
2015 Ford F-350...
Ezmark Lazerz S-Series (A44502)
Ezmark Lazerz...
AGT 750 QA Hammer (A44502)
AGT 750 QA Hammer...
2014 HYDRA RIG 40' 3-AXLE LAYDOWN TRAILER (A45333)
2014 HYDRA RIG 40'...
