Stay Bar Connection?
   / Stay Bar Connection? #1
BryEllis
Fingerlakes Central, NY
TS354C
On my 2003 TS354C there is an Eye bolt that passes through the drawbar between the lift rod and the implement connection. this eyebolt has a threaded link that is attached to the staybar turnbuckle.
There must be a better way to attach this as the eye-bolt bends and the drawbar ends up dragging on the opposite side tire. I have tried a 1/2 inch forged eyebolt but alas still not string enough.
The hole is a bit bigger than 1/2 inch but I cannot locate a 5/8" forged Eyebolt.
The turnbuckle is tightened up all the way. I have a welder and am thinking of fabricating a clevis with a plate that I can bolt to the drawbar.
Any ideas?
...Bryan
   / Stay Bar Connection? #2
I too am having the exact same senerio with mine. I replaced one already with the other already bent. If you have a local Ace Hardware close by they will have it or be able to order you one. Here's a link for an eyebolt . And you'll more than likely need a lap link for it as well. I was pondering the same thing for mine, it dosen't seem to hold up to well and seems to be a weak link.
Thanks for the link, I am trying a different approach... Turns out that a Category 0 Hitch pin is 5/8 of an inch... so I installed these and using i think 6 large flat washers on the outside of the lap link to take up the slack. Granted it looks a bit funky.
I just bush hoged and plowed about an acre and it looks to be holding up well.
...Bryan
2009 Dodge Grand Caravan Passenger Van (A53117)
2009 Dodge Grand...
2008 Nissan Titan Pickup Truck (A51692)
2008 Nissan Titan...
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
2009 DRAGON  130BBL VACUUM TRAILER (A53843)
2009 DRAGON...
2013 Husqvarna YTH18542 42in Riding Mower (A51694)
2013 Husqvarna...
